ABS light
2001 ISUZU RODEO
200,000 MILES • 3.2L • V6 • 4WD • AUTOMATIC
RACHEL SMITH
I have replaced a lot of my braking system over the last fourteen months, except my hubs. My ABS light is back on and not throwing a code. I do not want to do. what I did last time and charge everything again? Help.
Feb 1, 2017 at 3:20 PM
HMAC300
  • 48,601 POSTS
have another tester used it may be the one that was used that did not show anything. if it is on there is something wrong with it. also, erase the code if you can see if it comes back. may be a weak battery or dirty terminal ends.
Feb 2, 2017 at 5:53 AM
RACHEL SMITH
Okay, I will test it with another tester today. the battery is good at brand new and my post are clean.. Fourteen months ago when I bought the car did the same thing and I started with the small things and worked up to the big things so I got the light to go off, but again it would not throw code then either..
Feb 2, 2017 at 7:29 AM
SATURNTECH9
  • 30,869 POSTS
Also most diyer scan tool won't read abs codes and ones that do are git and miss they work on some Vechiles but not other one's.
Feb 3, 2017 at 7:04 AM
RACHEL SMITH
Yes you have to have a ABS scan tool not a OBD one..
Feb 3, 2017 at 7:56 AM
