My brake pedal started fading intermittently, and then would act normal. This lasted a few months. Now the brake pedal constantly fades. The vehicle will stop, but the pedal goes to the floor. No dash / warning lights. Replaced the master cylinder; no cure. Bought a used ABS assembly, reused my control module on sourced hydraulic valve and pump assembly. Made no difference. Bought scan tool to bleed ABS and scan for codes. System passed. The brakes act the same as before I started.
Sep 12, 2025 at 11:47 AM
