Good morning,
I attached the procedure and the pictures for you as well.
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
I assume your ABS light is on from this request. When you complete the job, drive the car. If your repair is successful the light will turn itself off at 8 MPH. That is a confirmation of the repair. No need to reset the light.
1. DISCONNECT SPEED SENSOR CONNECTOR
a. Remove the front wheel and front fender liner.
b. Disconnect the speed sensor connector.
2. REMOVE SPEED SENSOR
a. Remove the bolt, flexible hose and speed sensor harness clamp from the shock absorber.
Torque: 29 Nm (300 kgf-cm, 21 ft. lbs.)
b. Remove the resin clip from the shock absorber.
c. Remove the bolt and speed sensor harness clamp to the body.
Torque: 5.0 Nm (55 kgf-cm, 48 inch lbs.)
d. Remove the bolt and speed sensor from the steering knuckle.
Torque: 8.0 Nm (82 kgf-cm, 71 inch lbs.)
INSTALLATION
Installation is in the reverse order of removal.
AFTER INSTALLATION, CHECK SPEED SENSOR SIGNAL
Mar 4, 2020 at 4:20 AM
