1. If I depress the brake pedal and keep it depressed, then turn on the ignition, the ABS indicator comes on, extinguishes, and stays off. However as soon as I release the brake pedal, seconds later, the indicator comes on and stays on until I turn the ignition off. If I pump the pedal as the vehicle is running and ABS on, it remains on until ignition shutoff.
2. If I turn the ignition on without depressing the brake pedal first, ABS comes on, extinguishes, then comes back on and stays on until I turn the ignition off. It makes no difference if I depress or pump the pedal while the indicator is on. It stays on until the ignition shuts off.
In either situation the vehicle is not in motion.
Oct 7, 2022 at 12:08 PM
