ABS fault codes
2008 SKODA FABIA
135,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
DIMIS
ABS and traction control dashboard lights continuously on.ABS, ECU AND PUMP. tested found okay. Faults are 01201(voltage supply hydraulic pump) and 00301(hydraulic pump).40 AMP Abs fuse replaced,problem unsolved.
Jun 16, 2020 at 1:09 AM
With the key on can you use a test light to see if the fuse gets power? here is a guide to help:
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Jun 17, 2020 at 10:43 AM
