ABS code C2116
2008 JEEP PATRIOT
130 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
MTH1973
ABS light on.
Jul 19, 2019 at 7:12 PM
Welcome to 2CarPros.
That indicates low voltage to the ABS pump motor. Here are the diagnostics for it. Before going crazy, check and make sure there are no ground issues and check battery voltage. The attached pictures correlate with the directions.
2008 Jeep Truck Patriot 2WD L4-2.4L
ABS
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Testing and Inspection C Code Charts C2116
C2116-ABS PUMP MOTOR SUPPLY LOW VOLTAGE
pic 1
For a complete wiring diagram Consult Diagrams/Electrical.
- When Monitored:
With the ignition on and the ABS Pump Motor deactivated, but not if supply voltage faults are detected.
Or, if the control is switched off.
- Set Condition:
If the Anti-Lock Brakes Module detects either a low voltage condition when the ABS Pump Motor is activated or deactivated or a high voltage condition when the ABS Pump Motor is deactivated.
pic 2
Diagnostic Test
1. CHECK FOR A DTC C2116-ABS PUMP MOTOR SUPPLY LOW VOLTAGE
NOTE: This DTC must be active for the results of this test to be valid.
Turn the ignition on.
With the scan tool, record and erase DTCs.
Cycle the ignition switch from off to on.
Road test the vehicle over 40 km/h (25 mph).
NOTE: Vehicle must be driven above 40 km/h (25 mph) for set conditions to be meet.
With the scan tool, read DTCs.
Does the scan tool display: C2116-ABS PUMP MOTOR SUPPLY LOW VOLTAGE active?
Yes
- Go To 2
No
- Refer to the ABS-INTERMITTENT CONDITION TEST. See: Antilock Brakes / Traction Control Systems > Component Tests and General Diagnostics > ABS Intermittent Condition Test
Diagnostic Test
2. INSPECT RELATED WIRING HARNESS, TERMINALS, & CONNECTORS
Turn the ignition off.
Visually inspect the Anti-Lock Brakes Module harness connector and wiring harness for damage.
Check all related wiring for pinched, chafed, pierced, and partially broken wires.
Check all related connectors for broken, bent, pushed out, and corroded terminals.
Were any problems found?
Yes
- Repair as necessary.
- Perform ABS VERIFICATION TEST. See: A L L Diagnostic Trouble Codes ( DTC ) > Verification Tests > ABS Verification Test.
No
- Go To 3
3. CHECK ABS PUMP MOTOR FUSE
Remove and visually inspect the ABS Pump Motor fuse.
Is the fuse open?
Yes
- Go To 4
No
- Go To 5
4. CHECK (A921) FUSED B(+) CIRCUIT FOR A SHORT TO GROUND
pic 3
Disconnect the Anti-Lock Brakes Module harness connector.
Measure the resistance of the (A921) Fused B(+) circuit between ground and the Anti-Lock Brakes Module harness connector.
Is the resistance below 10k ohms?
Yes
- Repair the (A921) Fused B(+) circuit for a short to ground.
No
- Go To 5
5. CHECK (A921) FUSED B(+) CIRCUIT FOR AN OPEN OR HIGH RESISTANCE
pic 4
Replace the ABS Pump Motor fuse.
Using a 12-volt test light connected to ground, probe the (A921) Fused B(+) circuit.
NOTE: The test light should illuminate brightly. Compare the brightness to that of a direct connection to the battery.
Does the test light illuminate brightly?
Yes
- Go To 6
No
- Repair the (A921) Fused B(+) circuit for an open or high resistance.
6. CHECK (Z909) GROUND CIRCUIT FOR AN OPEN OR HIGH RESISTANCE
pic 5
Using a 12-volt test light connected to 12 volts, probe the (Z909) Ground circuit.
Does the test light illuminate brightly on both circuits?
Yes
- Go To 7
No
- Repair (Z909) circuit for an open or high resistance.
7. REPLACE ANTI-LOCK BRAKES MODULE & VERIFY IF DTC IS STILL ACTIVE
Replace the Anti-Lock Brakes Module.
With the scan tool, read ABS DTCs.
Does this DTC reset?
Yes
- Replace the Hydraulic Control Unit.
No
Let me know if that helps.
Jul 19, 2019 at 7:35 PM
