The brake pedal goes almost to floor, it would stop the car. Pads and shoes are about 50% or less. Have tried bleeding the brakes starting at the master cylinder/ABS unit. I read about the gear timing on the ABS pump and followed the Haynes car manual, the ABS and Brake light are now off {after adding brake fluid. What i would like to know is can I buy a regular brake master cylinder an eliminate the ABS System? Would I nee to go to a salvage yard and get the proportioning valve and brake lines up to master cylinder, or should I buy a new master cylinder and try to replace myself? I am an experienced mechanic but never messed with ABS unit before. Basically needs a new master cylinder, but not sure if gear timing is where it should be to perform bleeding procedure! Please help! {Jim} Thanks for your time!
Feb 26, 2017 at 4:08 AM
