ABS brakes and AdvTrack
2005 FORD EXPLORER
200,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
GREG4272
  • 4 POSTS
I have seen other posts about this issue but I am interested in any opinions you can offer. when I first drive off in my truck, the brakes lock up and the truck drops into four wheel drive high. It will not roll at all and will occasionally jerk until I pull over. I have to turn the steering wheel left and right to get it to move. after about five minutes of this suddenly the AdvTrak light will kick on and the truck will move freely. I have had sensors changed but nothing has solved the problem. any advice would be greatly appreciated.
Jan 17, 2018 at 3:46 AM
Good morning.
Are there any codes in the ABS system?
Jan 17, 2018 at 3:52 AM
GREG4272
  • 4 POSTS
None. all those boards have been replaced by a mechanic and Ford reprogrammed the system.
Jan 17, 2018 at 8:01 AM
I would still have the system checked for codes for a malfunction in the AdvTrac system which is part of the ABS.
Also, has anyone checked the brakes? Particularly the front brake hoses?
Jan 17, 2018 at 8:04 AM
GREG4272
  • 4 POSTS
Brakes are brand new. thought that was the problem initially. someone suggested it might be the ball bearings. watch the video and see if it helps explain it.
Jan 17, 2018 at 9:48 AM
what about the brake hoses??
Jan 17, 2018 at 5:08 PM
Yes, that does sounds like a wheel bearing that is out. Can you tell if it is front or rear? The video is great by the way. the only way to go for noises.
If it is front the front this guide will give you an idea on what you are in for when replacing the bearing hub.
https://www.2carpros.com/articles/bearing-hub-replacement
Below is how it will be for your car. You can get the part from Amazon I suggest doing both sides.
Check out the diagrams (below).
Jan 17, 2018 at 5:13 PM
GREG4272
  • 4 POSTS
Thank you so much. I wish I had asked for your help earlier.
Jan 18, 2018 at 3:17 AM
Good to hear, please use 2CarPros anytime we are here to help.
Jan 18, 2018 at 10:15 AM
