brake is locked up
2000 FORD MUSTANG
163,000 MILES • V6 • RWD • AUTOMATIC
MUSTANGMATT42
  • 4 POSTS
The car sat for a few years now trying to get her back on the street, and ABS light is stuck on and front passenger side brake is locked up. I have replaced pads and caliper bled the brakes light is still on and brake still locking up the tire. I am stuck no idea what is wrong.
May 9, 2017 at 9:58 PM
CARADIODOC
  • 34,306 POSTS
When the brake is sticking, stop on a slight incline, shift to neutral, place a block about a foot downhill of one tire, then loosen the steel lines at the master cylinder. Hope the brake does not release. If it does, we will have to discuss the solution. It will likely cost more than the car is worth.
If the brake did not release, crawl underneath and open the bleeder screw on the sticking caliper. If that lets the brake release, the best suspect is a constricted rubber flex hose. A few more tests will verify that.
Mar 11, 2021 at 2:27 PM
MUSTANGMATT42
  • 4 POSTS
That will not really work, as it is the tire sticking, the car still moves freely and normally but the tread is clearly wearing faster, and if driven a lot you can smell the brakes from rubbing the rotor.
CARADIODOC
  • 34,306 POSTS
So the brakes are not sticking, yet they are getting hot? Something is rubbing, but the car moves freely? Any chance you can post a couple of photos, including the lower ball joint? Was this problem occurring before the brake parts were replaced? What area of the tread is wearing?
STEVE W.
  • 15,113 POSTS
Remove the tire. Pump the brakes a couple times then back the brake bleeder out. If you get a spurt of brake fluid you probably have a bad rubber brake line. When you apply pressure the damaged hose acts like a check valve and holds the brake on just enough to cause the brakes to get hot.
The other option is a bad wheel bearing that is letting the rotor shift and rub the brakes. It would cause tire wear but if it's that bad it should be readily noticeable.
MUSTANGMATT42
  • 4 POSTS
But would a bad wheel bearing cause a ABS light?
CARADIODOC
  • 34,306 POSTS
If it lets the rotor tilt, the tone ring can move way from the wheel speed sensor, and that will cause a loss of signal even though the computer sees the circuit is okay electrically. The type of defect will be described in the diagnostic fault code. Those need to be read from the ABS Computer and recorded to tell us where to start.
MUSTANGMATT42
  • 4 POSTS
It makes no noise, rotor is wearing normally, I'll have to go more indepth this weekend
Please let us know what you find ;)
