abs brake warning light came on.
1993 FORD FAIRMONT
180,000 MILES • 4.1L • 6 CYL • RWD • AUTOMATIC
SCOTTYDEG
I changed my car battery recently and after I started the car and went around the block I noticed the abs warning light came on. The brakes were fine before my battery died and now since the light came on, there definitely seems like there's no brake assist anymore. Whats goin on?
Apr 9, 2014 at 5:55 PM
CARADIODOC
  • 34,306 POSTS
A lot of anti-lock brake systems provide the power assist too. When the warning light is on, the computer has turned the system off. Given the recent battery replacement, the most likely suspect is a blown fuse. That often happens from the current surge when the battery is reconnected. Check the fuses first. If none are blown, you'll need a scanner that can access that computer to read the diagnostic fault code.
Apr 9, 2014 at 6:01 PM
