It will affect traction control if the fuse is pulled. See the following.
ABS Control Module (EBTCM)
The ABS control module monitors the speed of each wheel to detect wheel slip. If wheel slip is detected, the module commands the appropriate valve positions in the valve assembly to modulate brake pressure in some or all of the hydraulic circuits. This action prevents wheel slip and provides optimum braking. In addition, the ABS control module performs a continuous diagnostic routine to detect malfunctions. If the module detects an electrical malfunction, it can disable ABS/TCS/DRP, illuminate the appropriate telltale and store a Diagnostic Trouble Code (DTC).
If the ABS light was staying on, the aforementioned operation would not have worked.
I hope this answers your question. Let me know if you have others.
Oct 14, 2018 at 5:28 PM
