my scanner will not auto bleed the brakes?
2003 RAM 2500
250,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
HIPPY76
  • 5 POSTS
Trying to figure out why my scanner won't auto bleed these brakes on the truck listed above.
Nov 20, 2023 at 4:15 PM
Auto bleed? Can you please give me more details? Do you open the bleeder and think the scanner will do the bleeding? If so, please watch this video of how the job is done:
https://youtu.be/nQRnKyVyMuQ?si=jZ5m2FcJGjnI2jov
Nov 21, 2023 at 11:30 AM
HIPPY76
  • 5 POSTS
It says I need a Chrysler (CCD) connector, or I might not be able to test the ABS and orc module?
Nov 25, 2023 at 10:58 AM
I don't think so, you should be able to open the ABS valves through the ALDL diagnostic connector using the scanner, is this truck inside of the US?
Nov 26, 2023 at 11:21 AM
HIPPY76
  • 5 POSTS
My scanner is a Foxwell 624 elite and it says I need a ccd cable to do the auto bleed.
Nov 29, 2023 at 12:45 PM
you have this one, correct?
https://www.foxwelltech.us/product-detail-606.html
It does not say it opens the ABS valve.
Nov 30, 2023 at 10:36 AM
HIPPY76
  • 5 POSTS
That's the scanner I have yes.
Nov 30, 2023 at 8:16 PM
It does not look like this scanner has the capability to open the ABS valves like in the video, but it is hard to tell because there is conflicting information. Can you upload an image of the screen where you sepec the ABS valves can be opened?
Dec 1, 2023 at 9:38 AM
HIPPY76
  • 5 POSTS
As soon as I click on ABS auto bleed, it pops up a message saying I need a CCD cable to do it.
Dec 2, 2023 at 4:15 PM
HIPPY76
  • 5 POSTS
And it works on other vehicle.
Dec 2, 2023 at 4:19 PM
Okay, I don't know on that scanner, maybe you need to cable. Does the scanner manufacturer have a support line you can call?
Dec 4, 2023 at 9:43 AM
