ABS and anti skid lights stay on
2011 FORD RANGER
82,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
Replaced front ABS sensors , ABS and anti skid lights stay on on and off anti skid button will not work?
Nov 12, 2020 at 8:48 AM
Good afternoon,
There is a fault stored in the system. We need that fault. You can stop at a parts store and see if they can read the ABS system for faults. It sounds like you may have a wheel speed sensor that is out. These videos will help us find the problem.
https://youtu.be/rTtAnsOlZU4
and
https://youtu.be/Pb6nXV-iamI
and
https://youtu.be/ANWVTh2RQoQ
and
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Please run down these guides and report back. Once I get that code, I can help track down the area of failure. Once the ABS is repaired, all the other systems will work again.
Nov 12, 2020 at 1:56 PM
Have you checked for codes? If so, what are they because that is going to tell us where the issue is.
Clearly these lights are commonly a wheel speed sensor issue but we need to start with the codes and then we can test the sensors if needed.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Let's start here and go from there. Thanks
Nov 12, 2020 at 1:57 PM
Thanks for your help. after I changed the sensors , the lights where still on, but then i drove it down the road and wow, they went out. so everything is fine. thank you again for your time....
Nov 13, 2020 at 3:17 AM
The ABS system self checks when you first start it. When the repair is successful, the light goes out when you get to 8 MPH.
You are welcome.
We are always glad to help.
Nov 13, 2020 at 4:23 AM
