ABS and traction light on solid?
2012 DODGE CHARGER
190,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
429BOSS
ABS light on solid changed sensor still on wiring looks good. Get code C0037-62. I’m thinking tone ring, but I could be wrong. any suggestions would be greatly appreciated. thank you very much.
Mar 15, 2025 at 12:34 PM
It looks like the left rear sensor is not working, I would replace the sensor first and at the same time check the rear bearing hub for play, this can also cause the sensor not to work.
The C0037-62 code refers to an issue with the Left Rear Wheel Speed Sensor and specifically indicates a Signal Compare Failure.
Please go over this guide which can help:
https://www.2carpros.com/articles/7-common-symptoms-of-a-bad-automotive-bearing-hub
You may need to clear the codes as well when the job is completed. Here is the location of the sensor. Check out the images (below). Let us know how it goes.
Mar 15, 2025 at 6:57 PM
429BOSS
Thank you, Ken. I checked the wheel hub looked good but replaced anyway. Also replace tone ring on axle/ Reluctor ring. Worked great all lights off. Thank you very much for your time to respond great site you have here. Thank you again
Mar 22, 2025 at 11:19 AM
Glad you could get it fixed, thanks for letting us know. Can you please leave us a rating?
https://g.page/r/CZdEnyCkGgm6EB0/review
and
https://www.sitejabber.com/reviews/2carpros.com
Thank you!
Mar 23, 2025 at 9:26 AM
