ABS and traction control light on?
2006 BUICK LUCERNE
170,000 MILES • 3.8L • 6 CYL • AUTOMATIC
ROBIN MOCABY
After you drive 20-30 miles when you stop then go again it shifts hard. Set for a bit then it drives ok, it comes and goes.got bearing replacement, swaybar, tie rod ends. That stopped air leaking in front tires but didn't fix problem. The brake fluid is dark and dirty. Never seen that before
Aug 29, 2025 at 8:51 PM
It is normal to have the brake fluid look dirty, it means it needs to be flushed please watch this video to show you how.
https://www.youtube.com/watch?v=w7gUsj2us0U
We should run the codes to see which ones are stored, this will let us know which sensor or module is having an issue, here is a video for that as well.
https://www.youtube.com/watch?v=HvooM1X2SDs
Did you have the light on before the bearing hub replacement?
Aug 30, 2025 at 5:56 PM
