ABS and traction control light
2002 CADILLAC DEVILLE
156,387 MILES
KENNY WAYNE MILES
I pulled up the codes on my car and it showed C1232, C1282, C1284, 85, 87, and 88, what procedure must I follow to rectify this problem? I have already tried clearing the codes and nothing happen, I also replaced the ECBM.
Dec 19, 2017 at 11:02 AM
These car had a problem with the wheel bearings which is where the ABS speed sensor is located. Which created the codes. Here is a guide to show you what you are in for when doing the job.
https://www.2carpros.com/articles/bearing-hub-replacement
and
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Dec 20, 2017 at 2:28 PM
KENNY WAYNE MILES
My mistake, I failed to mention that I replaced both wheel bearings also. I may have waiting a little too long before doing so because it made that winding noise for a couple months before I finally changed them. Maybe that could have something to do with it?
Dec 21, 2017 at 6:25 AM
Good Morning
Did you check the rear sensors?? If you have an ohm meter you can check the resistance of the sensors. They should be 800-1100 ohms. Make sure the connectors are clean and tight with no damage to the pins.
Dec 21, 2017 at 6:51 AM
