On the instrument panel, the ESP, BAS, ABS, Brake, and check engine light came on and the speedometer no longer works. The fuel economy drops rapidly, I assume because it is not receiving any speed input. The tachometer works fine.
I have the following codes:
U1110 - Lost vehicle speed
U0121 - Lost communication with anti-lock brake module
U1120 - Lost wheel distance
I am wondering if this might be a bad abs wheel speed sensor or some other sensor/component. If so how do I determine which wheel the bad sensor is on?
Thank you for any guidance you have on this!
Sep 30, 2023 at 11:12 AM
