Because this vehicle isn't offered in the US, I don't have wiring schematics. However, you can check each wheel speed sensor individually.
If you take a look through this link, it explains how to test a wheel speed sensor while it is on the vehicle.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Also, considering how new this vehicle is, you could scan the can-bus or if you have a live data scan tool, watch each wheel speed to see if one is off.
Here is a link that explains how the can-bus is checked:
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Let me know if this helps or if you have other questions. Although I don't have the schematics, the circuits all primarily work off the same principles.
Oct 20, 2022 at 8:18 PM
