Couple questions. Did the hub you replaced come with a new wheel speed sensor on it with a connector pigtail? If so, we need to unplug it and plug it back in and make sure it is a good connection.
Next we need to scan for codes but I am sure if this is all that happened then the wheel speed sensor is our issue in some way.
https://youtu.be/rTtAnsOlZU4
Let's confirm this with the codes and check the connection and then go from there. Thanks
Jun 15, 2020 at 6:55 PM
