ABS and brake light on
2005 CHEVROLET TRAILBLAZER
215,000 MILES • 5.8L • V8 • 4WD • AUTOMATIC
TRAILBLAZER2005
After changing wheel speed sensor and brake pads still getting ABS light. When I come to a stop brake peddle scrubs but if I unhook sensor scrub stops and brake light stays on saying service brakes soon.
Nov 21, 2019 at 3:05 PM
Good afternoon,
Did you have the code checked? A part store will read the code for free.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
The fact you disconnected the sensor disabled the system so, yes, the issue stopped happening.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Verify the fluid level is correct in the master cylinder as well.
Feb 27, 2021 at 1:35 PM
