abs and brake light on
2004 FORD FOCUS
242,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
FARR2007
  • 244 POSTS
ABS light is on after new front pressed bearings installed, code for ABS is c1234. also, I had a rear drum replaced because of bad bearing and that code is c1236. brake light goes out when shut car off, but soon as you drive a block or less it will illuminate.
Feb 14, 2017 at 12:07 PM
WRENCHTECH
  • 20,761 POSTS
You have a problem with the right front and left rear speed sensors. Something in the sensor may have gotten damaged or the tone ring is out of position for some reason. The issue is definitely related to the work done.
Feb 14, 2017 at 1:04 PM
FARR2007
  • 244 POSTS
Are you positive on this and how do you fix it? Also, would you know how to disconnect the ABS sensor from the harness to put new one in? But how would I fix the back also?
Feb 14, 2017 at 1:45 PM
WRENCHTECH
  • 20,761 POSTS
I am positive the speed sensors are no longer reading on those two wheels. Someone else has to determine the actual cause. Do not assume it is the sensor itself unless you actually, physically broke it.
Feb 14, 2017 at 1:48 PM
FARR2007
  • 244 POSTS
But you think it is the sensors so why should I not assume that it is the sensors? also, have you heard of a P1000 code?
Feb 14, 2017 at 4:51 PM
FARR2007
  • 244 POSTS
So how can I fix this?
Feb 14, 2017 at 4:52 PM
WRENCHTECH
  • 20,761 POSTS
When did I say I think it is sensors. You have an issue with the sensor circuit that may or may not be caused by the sensor itself.
It could be a problem with the tone ring or the wiring. It is highly unlikely two sensors failed at the same time unless you simply broke them.
The P1000 code simple means you recently cleared the codes.
Feb 14, 2017 at 4:55 PM
FARR2007
  • 244 POSTS
Well the mechanic put in the bearings In front and and came on and after he put new drum and bearing in rear the brake light came on as soon as I start driving. should I be concerned about these as in will it affect driving? What would I need to do to fix? How much you think it would cost? I do not even know where to get a tone ring? I am not sure if new rear drum had a new abs ring on it because I do not think he transferred the ring.
Feb 14, 2017 at 5:22 PM
WRENCHTECH
  • 20,761 POSTS
Well, if the new drum did not have a ring, you just solved one of your problems.
I do not even know why you are trying to deal with this. This problem belongs to the mechanic that did the job. He is the one that caused it.
The only issue with driving it is the ABS system has been disabled so you just have regular brakes.
Feb 14, 2017 at 5:26 PM
FARR2007
  • 244 POSTS
And the rear brake light could be from the drum possibly if it do not have that ABS ring on it? They did not fail at same time one was done a few weeks later.
Feb 14, 2017 at 5:38 PM
FARR2007
  • 244 POSTS
Please reply back with more information please.
Feb 15, 2017 at 7:21 AM
WRENCHTECH
  • 20,761 POSTS
There is no more information I can give you at this time. The system needs to be inspected to determine what was damaged or left off when the repairs were made.
Feb 15, 2017 at 8:13 AM
FARR2007
  • 244 POSTS
Can you at least tell me where the rear sensors are because I know where the front are?
Feb 15, 2017 at 10:53 AM
WRENCHTECH
  • 20,761 POSTS
All you have to do is follow the wire into the back of the wheel. https://www.2carpros.com/images/external/108690812.gif
Feb 15, 2017 at 11:09 AM
FARR2007
  • 244 POSTS
where is the tone ring located? i bought a new cv axel and on the box it shows the new tone ring but on the part i cannot see one, i am having trouble locating a axel with a tone ring or is it all a sealed unit? is it internal?
Feb 21, 2017 at 3:15 PM
WRENCHTECH
  • 20,761 POSTS
I can't find any pictures on this one. It's either going to be on the C?V joint or part of the hub bearing. If you remove the sensor, just look inside the hole for the teeth.
Feb 21, 2017 at 3:20 PM
FARR2007
  • 244 POSTS
well with the new axel i bought i dont see any teeth and ford just said ypu can buy just the tone ring separate
Feb 21, 2017 at 3:32 PM
FARR2007
  • 244 POSTS
did ford change the design?
Feb 21, 2017 at 6:43 PM
WRENCHTECH
  • 20,761 POSTS
If the car is available with or without ABS then the axle would also be available with and without the tone ring if that is actually where it goes.
Feb 21, 2017 at 6:45 PM
FARR2007
  • 244 POSTS
I am so confused as to this tone ring situation, I don't know what style my car has because I never had axel off I need to figure this out
Feb 22, 2017 at 3:39 PM
FARR2007
  • 244 POSTS
ok so on top of having the c1234 NS C1236 codes, I now have c1145 and c1175
Feb 23, 2017 at 11:03 AM
Hey FARR2007,
It seems like we making a little problem into a big one, get the axle that has the ABS stator ring and the problem will be fixed.
Please let us know happens.
Best, Ken
Feb 26, 2017 at 12:15 PM
