Yeah. The wheels will not effect this because the wheel speed sensors run off a sensor to a tone wheel.
The gaping does matter but you would not use a spark plug gap tool because it is a different style gaping. You would actually use spacers/washers on the base of the sensor to increase or decrease the gap.
Here is a 1980's style video that shows this really well:
https://youtu.be/AvQlHxZuVGw
I doubt this is the issue. If you are saying there are multiple other sensors in the glove box then I suspect they tried to replace them. Again, when having these different codes I suspect there is a module issue so we need to run through that testing just to find out where the issue is.
While it could be each sensor, I have never seen all these sensors fail at the same time which is why I suspect there is a greater issue.
Mar 31, 2020 at 9:37 AM
