ABS and all wheel drive lights on
2007 MERCURY MOUNTAINEER
199,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
ZAIRE
ABS all wheel drive on sometimes go off. When they come back in the wheel make strange noise or sometime when I drive around 35 miles they lock by the self. how I can fix? I went to couple mechanics and everybody said something different.
May 31, 2019 at 2:27 PM
It sounds like you have a front wheel bearing hub that is going out which effects the sensor and ABS/traction control system.To confirm lets run the codes to see which sensor is giving us trouble. I will also include a video on how to change the hub out on a similar car.
https://youtu.be/rTtAnsOlZU4
and
https://youtu.be/ZgiPRG6jffc
Jun 1, 2019 at 2:58 PM
ZAIRE
Has 2 code C1145 and C1155.
Jun 1, 2019 at 5:28 PM
These are for both front ABS wheel speeds sensors. I would replace both front bearing hubs here are diagrams to show you how. Check out the diagrams (below). Please let us know what happens.
Jun 4, 2019 at 10:14 AM
