In the past couple of months my vehicle has had the ABS and 4WD lights on dash/chime Intermittently.
I took it into the GM dealer and they did a diagnostic and said it was a ground issue.
Shortly after it did it again but then went away and yesterday it happened non-stop. This morning nothing..
Took it to the GM dealer and they wanted $1,315.00 to replace some module yet they could not recreate the issue.
I am at a loss here because I feel like it's moisture related. seems it comes on day when we drive through snow and slush. Maybe I am a fool for thinking that but that is the only common factor that I can recount.
Any thoughts or suggestions?
Or at a minimum how do I stop the warning sound maker... hard to drive it any distance with the chime go off non stop.
Thank you in advance.
Jan 2, 2020 at 3:02 PM
