ABS light on VSC off light flashing
2010 TOYOTA COROLLA
225,000 MILES
DALE PETRY
Can I pull codes without a scan tool? Tried jumping pins 4 and 13 at the ddl connector under dash and got ABS flashing code 91, but no listing for this code. Maybe not able to read code on this newer model.
Jan 14, 2021 at 7:32 AM
SEVAG P
  • 405 POSTS
The easiest way to read fault codes is by using scan tool, ABS fault codes appears as(C) codes for example check the tables at figure 1.
Check the fault code then together will can properly troubleshoot and repair your problem.
Thank you.
Jan 15, 2021 at 9:01 AM
DALE PETRY
Any way to pull codes without a scan tool?
Jan 15, 2021 at 10:26 AM
SEVAG P
  • 405 POSTS
hi again,
no, the proper way to read faults by using scan tool. only at old cars without OBD socket can be pulled the fault codes by counting the blinking of the check engine light then check on workshop manual.
let us know if you need more help.
Jan 16, 2021 at 1:03 PM
DALE PETRY
Thanks. That is what I thought. Thank you
Jan 16, 2021 at 1:17 PM
SEVAG P
  • 405 POSTS
You are welcome let us know if you need more help.
Jan 16, 2021 at 2:02 PM
