ABS light on, tested DC voltage at connector 4.85v with probes in one direction, 3.17v with probes in other direction. Stationary AC voltage on sensor .08v. When rotating hub I get .1 volts. Shouldn't stationary voltage be 0.0v? The sensor is part of the wheel hub so I can't look at tooth wheel or air gap. ABS codes are C1226, C1233, and C1236. Ohms across sensor was 2093.
Aug 18, 2022 at 7:42 AM
