Abnormal thumping noise while driving
2004 FORD FOCUS
163,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
BUCCOFEVER1995
The car makes the sound almost like a washing machine would make. When I’m driving straight. It goes faster at higher rpm. But is noticeable even at slow speeds. I can feel the thumping noise in the floor too.
Jun 25, 2019 at 4:07 AM
Hi Buccofever,
This sounds like a tire issue. Normally, when you hear and feel a thumping noise the tire is the issue. Clearly it is something that is spinning while the vehicle is moving. So that means it could be tires or possibly axles. However, I would inspect the tires for wear before you replace any other parts. You are looking for flat spots or abnormal wear.
Here is a guide that helps explain this:
https://www.2carpros.com/articles/how-car-tires-work
Let me know if you have questions and we can go from there.
Jun 25, 2019 at 6:46 PM
