Hi guys!
I'm sorry to bother you again, but when you sent me an answer yesterday about bolting the pump back on after I replace the O-ring on that A113L auto Nova trans, you pointed out that I have to have those rubber sided washers with the bolts, or it will leak with heat! That makes perfect sense to me, but I don't remember seeing those washers either on the original trans, or the one I'm putting in-again! With you pointing that out to me, I'm sure that's why it was leaking still after the last time I put it in. Should I go to a dealer, or do you know where I can get those washers? Thank you big time!
Kevin
Kevin
May 24, 2015 at 11:33 PM
