A113L 1987 Chevy Nova trans bolt washers
1987 CHEVROLET NOVA
27,000 MILES • 1.6L • 4 CYL • FWD • AUTOMATIC
BUTTS6954
  • 4 POSTS
Hi guys!
I'm sorry to bother you again, but when you sent me an answer yesterday about bolting the pump back on after I replace the O-ring on that A113L auto Nova trans, you pointed out that I have to have those rubber sided washers with the bolts, or it will leak with heat! That makes perfect sense to me, but I don't remember seeing those washers either on the original trans, or the one I'm putting in-again! With you pointing that out to me, I'm sure that's why it was leaking still after the last time I put it in. Should I go to a dealer, or do you know where I can get those washers? Thank you big time!
Kevin
May 24, 2015 at 11:33 PM
WRENCHTECH
  • 20,761 POSTS
You need to post your replies to your original question. The original expert will be notified and the info will maintain continuity.
May 25, 2015 at 5:10 AM
