A popping sound when idling coming from one side of the exhaust?
1995 CHEVROLET CAPRICE
130,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
CJLOVELESS
  • 6 POSTS
I have the car listed above Classic. It has a popping sound when idling coming from one side of my exhaust, and it pops a lot more when I go to accelerate and barely goes. it won't go over like 40 MPH, and it takes a long time to get up to 40 MPH. I've changed the plugs, TPS, and took the catalytic converter off. I've checked my fuel injectors and my fuel pressure. I'm stumped here.
Sep 2, 2023 at 9:42 AM
It sounds like you have a broken valve spring or a blown head gasket between two cylinders, either way a compression test can help us see what's going on, also if you upload a short video of the noise, I can tell for sure what's going on.
This guide can help us get started on fixing the problem:
Sep 2, 2023 at 6:24 PM
CJLOVELESS
  • 6 POSTS
It might not be the best video but if it's not good enough let me know and I will record another video.
Sep 2, 2023 at 9:11 PM
Thanks for the video. it does sound like a broken valve spring, or the valve train has fallen apart, you can remove the valve covers for an inspection. Use a flashlight it helps with the inspection. Please check the image below to see what I am talking about.
Sep 3, 2023 at 10:48 AM
CJLOVELESS
  • 6 POSTS
Okay, thank you. I'll check into that and let you know the verdict.
Sep 4, 2023 at 8:19 AM
Please do, if you find something you have a question on please upload an image a short video.
Sep 5, 2023 at 10:44 AM
CJLOVELESS
  • 6 POSTS
There is a lot of oil shooting out of the 1 and the 3rd on in the passenger side going from right to left.
Sep 13, 2023 at 1:09 PM
Wow, you are not kidding, thanks for the video. It looks like the engine has a spun bearing which is affecting the oiling of the engine and making the noise. You are going to need to remove the engine and disassemble it to find the problem.
Sep 14, 2023 at 10:37 AM
CJLOVELESS
  • 6 POSTS
Man, that's just too much for me to get into. I don't really have the time, but thanks for all your help.
Sep 14, 2023 at 11:13 AM
You are welcome, use 2CarPros anytime, we are here to help. Please tell a friend.
Sep 15, 2023 at 10:12 AM
