I seem to have a draw on my car battery. I checked my amp draws and came up with .53 and it should be between 30-50. So I started pulling fuses and found the stop fuse dropped to .39 .
This should mean that something in the stop fuse system is drawing some power. Nothing seems to be wrong. All the lights and brakes signals work. Brake switch works. Can anyone make a suggestion? Maybe a body control module (BCM) shorted? But where would that be.
The battery drains after about three days to a dead battery. I cannot find where the draw is in that circuit. 0.53 miliamps. The readings were taken after the car went to sleep. About fifteen seconds.I did not turn on the ignition to do the test. I just made sure the battery was charged.
Thank you. Craig
Thank you. Craig
Feb 28, 2017 at 12:26 PM
