A loud thump periodically from gas tank area
1992 GMC VANDURA
130,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
NICKDAMONE83
  • 6 POSTS
From time to time and not in any certain circumstance that I've noticed there is a thump or bang that comes from under the van.It sounds like it's in the area of the gas tank. wondering what this is and what could be causing this? any suggestions would be greatly appreciated and thanks in advance... Sincerely, Nick Williams
Oct 8, 2019 at 8:01 PM
Welcome to 2CarPros.
Nick, is it something you can actually feel? Are there any symptoms that may indicate an issue with a universal joint on the drive shaft? Take a look through this link:
https://www.2carpros.com/articles/how-u-joints-work
Often times, a bad joint will be felt via a vibration at certain speeds. It can make a clunk noise or bang if bad.
Also, a very common issue is related to exhaust hangers breaking and allowing the exhaust to bang off the underside of the vehicle or a component. Check under the vehicle to make sure the exhaust is tight and doesn't move around.
One last thing. Is there anything that you can do to cause it to make the sound?
Oct 10, 2019 at 7:33 PM
