sputtering and shutting off after someone put flex fuel in the tank to fill it a couple times?
2011 CHEVROLET EQUINOX
167 MILES • 2.4L • V6 • 4WD • AUTOMATIC
JUST J
I used to intuitively have the know-how for any problem I experienced in a vehicle and nowadays, I can’t diagnose a thing for all the “extra” info clouding my judgement, nevertheless, my vehicle is sputtering and dying after someone put flex fuel in the tank to fill it a couple times, and a couple bottles of fuel cleaner afterward. I was advised to put a cap or two of two cycle engine oil in it to lubricate the valves and injectors and now it’s acting worse than ever. There’s also a tire monitoring system out of service and a leak somewhere from the bottom of the coolant surge tank only leaking when it’s filled, which has been done with two different kinds of coolant. I have a store brand chip reader. I wonder if it will pick up the problem. Help! I don’t even know where to start!
Apr 19, 2023 at 6:32 PM
Let's start by reading the codes and I need to ask if you have had a tune up and a throttle body service.
Here are some guides to help us get started on fixing the problem:
and
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
and
Please go over these guides and report back.
Apr 20, 2023 at 11:42 AM
