a kluncking noise when i hit bumps or holes.
1998 AUDI QUATTRO
2.3L • 6 CYL • AWD • AUTOMATIC
BART KOSKI
  • 29 POSTS
the sound comes from front passenger side, when i drive over bumps or in pot holes there is a kind of thumping knock like something loose. i replaced drive axle, front lower and front lower rear control arm,steering knucklek and break pads. any ideas.
Apr 20, 2014 at 2:14 AM
HMAC300
  • 48,601 POSTS
check for a bad wheel bearing drive car in a circle in an empty parking lot in opposite direction if it increases noise it is on rh side if turning leh and vice versa
Apr 20, 2014 at 10:08 AM
EXOVCDS
  • 1,883 POSTS
Check your sway bar bushings.
Thomas
Apr 20, 2014 at 6:15 PM
BART KOSKI
  • 29 POSTS
thanks, I tried that and there was no difference its only when I hit bumps or holes. I took off tire once again and this time I found the top front support bar was loose.t there is five on either side.
Apr 24, 2014 at 7:32 AM
