A ir conditioning malfunction
2004 HONDA CRV
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOSEPH GLEESON
Hi the problem is that after changing the thermal fuse and thermistor, now when I turn on the motor switch to positon ll , the air condition blower starts working, even the blower switch is off!!, there is no speed change, And if I put to operate the ac/cold, it cools the air, but there is no way to turn off the blower, unless you switch off completely the car! What can it be the problem??
Mar 25, 2016 at 3:39 PM
HMAC300
  • 48,601 POSTS
check for a bad blower relay then have it scanned for codes there may be a problem with control head or blower power transistor on hvac unit.
Mar 26, 2016 at 8:15 AM
