Had a leak in A/C system, took to shop, they put in UV dye marker. Lasted 6-8 weeks. Got a UV light and found two leaks, one at low pressure fitting and one at the bottom of the drier. Replaced both low and high pressure hoses and drier/condenser assembly. Recharged to 1.1lb of R134a. Now works for about 15 minutes and the compressor turns off for about another 10-15 minutes. Got home and compressor was off, got pressures gauges attached seam fine, compressor started up again and let it run for 20-30 minutes, didn't shut down again and it was frigid inside car.
Aug 15, 2019 at 2:08 PM
