I had the A/C diagnosed at my mechanic. He started it manually and everything was working well. Blowing cold air. He said the problem was the climate control module. I had it repaired and installed it. The module works well but the A/C still won't come on. I checked fuses and that is okay. There is 12-volts at the compressor according to the OBD from the module. The coolant temperature was 194F. I don't understand why the clutch won't engage when not done manually. What else can it be? Any help would be appreciated. Maybe a relay but I have 12v at compressor.
Feb 11, 2022 at 9:26 PM
