I attached two of your pics and circled one thing in each. Looking at pic 1, that appears to be right where the transmission and engine are bolted together. In that picture, it looks like it could be either engine oil or dirty transmission fluid.
Pic 2 has me confused. Is where I circled where the leak appears? At that specific point of the vehicle (near the end of the front door), there really shouldn't be anything to leak. Is that where you see the leak in the morning? Have you checked the oil level and the transmission fluid level?
If that is either ATF or engine oil, that is a lot to lose. You should notice the level being low. Also, leaking valve covers can make it to where I see the drip in pic but not pic 2.
Do me a favor. The idea that the belt makes noise leads me to think it's getting either oil or engine coolant on it. The water pump has what is called a weep hole where coolant can leak if the seal or bearing goes bad in the pump. If it is getting on the belt, which is likely would, you will get a belt squeal. Open the hood and inspect the belt and around the water pump for evidence of a leak.
Take a look through this link also. It explains in more detail what I'm saying and provides pics. If the coolant is getting low, I have a feeling this is where the problem is coming from.
https://www.2carpros.com/articles/symptoms-of-a-bad-water-pump
Let me know. Also, Freon is a gas, so that isn't the cause.
Jan 2, 2022 at 5:59 PM
