A/C stuck on floor/defrost
2004 OLDSMOBILE ALERO
158,983 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
CHILIBOI44
My car's A/C has been stuck on the floor/defrost setting for a few months. When I turn the knob, it's loose and doesn't change where the air blows.
Jul 22, 2021 at 10:54 AM
SQM
  • 6,383 POSTS
It sounds like your mode door actuator is probably faulty.
The mode door actuator controls where to direct the airflow after your select it on the dash.
Many of these GM vehicles mode door typically fails on the floor/defrost setting.
https://youtu.be/Eqf-H3COtSo
I have attached replacement procedure for the mode door actuator.
Thank you.
Jul 22, 2021 at 11:35 AM
