You need to check the evaporator and see if it is freezing. I suspect you have an expansion valve issue. Basically, this controls the amount of expansion/evaporation the refrigerant does in the evaporator and when this fails, it allows the core to freeze and then it blows warm air because the ice does not allow the air to be cooled as it can't flow through the evaporator.
The evaporator is located in the HVAC housing behind the dash. More than likely you will be able to see it by following the AC lines in from the engine compartment and then looking through the fresh air inlet. Also, if the AC lines going into the firewall look like they have ice on them then you can be safe to assume the evaporator is frozen.
Last thing you can do is get the high and low side pressures while it is blowing warm. So drive it around until it starts doing this and then hook the gauges up to it. If you hook them up after it has sat, they will probably be normal because it takes about fifteen minutes for the evaporator to freeze and if this is it, we want to see what the pressures are when it is acting up.
Let me know what you find. Thanks
Jun 29, 2019 at 2:46 PM
