The system uses a relay for the A/C system which is under hood in the Power Distribution Module Engine Room (IPDM E/R) at right of engine compartment, behind the headlight.
Here are some diagrams (below) that show the location and here is a guide that will help you test the relay:
Please run this test and get back to us so we can continue helping you. Here are the HVAC system wiring diagrams because there are several fuses that run the systems as well:
Check out the diagrams (below)
(if you give this post a down vote please say why)
Jul 28, 2020 at 6:12 PM
(Merged)
