Hello, This is two problems that do not happen concurrently but I suspect they may be interrelated so I have included them both. The vehicle does have auto temperature and dual controls (GM RPO code CJ2).
The first problem is A/C randomly decides to start blowing hot air out either the driver or passenger side. One time it had fixed itself after it had been parked, shut off and sat for many hours, and another time it took disconnecting the battery for five minutes to bring it back.
The second problem is that the system randomly stops blowing air out the vents. When this happens I cycle through all the vent positions and hear air switching and changing internally. You can hear the air blowing and can also hear the blower motor running, but no air comes out the vents. I suspect the controller but was hoping to get a second opinion here before dropping money on a controller. they are not cheap! Thanks.
Jun 25, 2019 at 6:56 PM
