A/C does not blow cold on passenger side
2016 HONDA CIVIC
130,000 MILES • 2.2L • 4 CYL • 4WD • AUTOMATIC
BADGER78
When I turn on my A/C it blows somewhat cool on the passenger side but hot on the driver side. Help please.
May 18, 2018 at 2:54 PM
JIS001
  • 3,412 POSTS
That is usually an indicator that you are low on refrigerant. Have the system checked for proper charge. If low then you need to check for a leak.
Look at the condenser for green residue. If present replace the condenser. Check all lines and spray soapy water to service valves to check for leaks. If all is okay and you keep losing refrigerant then suspect a leaking evaporator. That repair would require removing the dashboard.
May 18, 2018 at 11:44 PM
BADGER78
Thank you so much for answering my question. In less then 24 hours! Unbelievable! I will absolutely give this a try. I will be sure to follow up with you to let you know the outcome. Thanks again! - Elaine
May 19, 2018 at 2:12 AM
JIS001
  • 3,412 POSTS
You are welcome and thank you for using 2carpros.
May 19, 2018 at 7:57 AM
