I replaced my A/C compressor because the clutch went out and was making noise, I vacuumed the system down then put in the Freon had readings of 40 PSI on low side and 200 PSI on high side checked temperature in car and was getting temperature of 43 degrees then heard the condenser fan come on went out and checked the readings and the low side went down to 20 PSI and the high side was fluctuating between 400. and 300 PSI and the compressor was kicking on and off.
I would appreciate any help you could give me.
Thanks, Carl
Thanks, Carl
Jul 27, 2022 at 12:54 PM
