With the car blowing hot air i went to recharge it i noticed that the gauge was flat and added Freon to the system. After a couple of short bursts the clutch engaged but is not cycling on and off it is just constant running but the air is still blowing hot. I took it for a test drive and rechecked the pressure and it was the same amount but the clutch was still engaged. Do I have to add more to the system until the clutch is cycling properly? Note: I believe there is debris where the blower motor is and i'm going to be checking it out. thank you
Sep 6, 2021 at 6:54 PM
