Code P1598, A/C pressure sensor voltage too high?
2002 JEEP LIBERTY
119,200 MILES • 3.7L • V6 • 2WD • AUTOMATIC
STEPHEN SMITH4
  • 9 POSTS
code P1598, which part needs to be replaced? Also, a hose under driver side near canister is just attached on one end. Where does the other end go? pic attached.
Oct 23, 2024 at 7:40 PM
STEPHEN SMITH4
  • 9 POSTS
code 0455 shows also; recent new fuel pump.
Oct 23, 2024 at 7:43 PM
We only handle one problem per thread sorry. Please start a new questions for other issues.
The P1598 code for a 2002 Jeep Liberty indicates a A/C Pressure Sensor Voltage Out of Range fault.
This is because the AC pressure sensor has gone out or the AC system is having an issue like low on charge, we should replace the sensor first. Here is the location, it should have a pressure valve under the sensor, so you don't have to vacuum down and recharge the system. If the system does need a charge, this video will help:
https://www.youtube.com/watch?v=uZrQCGwXfek
Oct 24, 2024 at 10:23 AM
STEPHEN SMITH4
  • 9 POSTS
I've already done the recharge. Is the sensor to replace item 1,2 or 3 in the diagram? Isn't there a picture of the actual item I need? And why are there 3 names for the same item? Is it a switch, a sensor or transducer?
Oct 24, 2024 at 2:34 PM
STEPHEN SMITH4
  • 9 POSTS
can the pressure sensor be removed without refrig removal?
Oct 24, 2024 at 5:32 PM
STEPHEN SMITH4
  • 9 POSTS
Since the compressor engaged when I added refrig and it is cooling nicely in cabin, could it be possible that just disconnecting battery will remove the check engine code, and it not need a new sensor? Would it be cooling if the pressure sensor were bad?
Oct 24, 2024 at 5:36 PM
It is 2/3 I don't know why they have two arrows there it is just one part; you should be able to replace the sensor without discharging the system. Once the sensor is replaced, clear the codes. The problem is the code is for a pressure switch, but there are two, one high pressure and one low pressure and the code does not say which one it is. But since you said the system gets cold, I would think it is the high-pressure switch. Check out the images (below). Please let us know what happens.
Oct 25, 2024 at 10:54 AM
STEPHEN SMITH4
  • 9 POSTS
how do i know which sensor to replace? are they the same to purchase?
Oct 25, 2024 at 11:41 AM
Correct they are the same procedure, I would start with the high side pressure sensor since the low side seems to be working.
Oct 26, 2024 at 9:14 AM
Correct they are the same procedure, I would start with the high side pressure sensor since the low sides seems to be working.
