A/C not working clutch not engaging
2000 FORD F-250
150,000 MILES • 7.3L • TURBO • 4WD • AUTOMATIC
DAVID LYONS2
A/C not working. vacuum was replaced. system pressure is good, no leaks. so with clutch not engaging. what could it be a switch or relay?
Jun 7, 2019 at 3:35 PM
Good evening,
Can you give me the pressures on both the high and low side? I need those readings.
I will attach a wiring diagram for you to view.
Jun 7, 2019 at 4:31 PM
DAVID LYONS2
Don’t have the readings they were done earlier this week by a mechanic.
Jun 7, 2019 at 5:52 PM
DAVID LYONS2
But I know he did, they were fine.
Jun 7, 2019 at 5:53 PM
Was it okay after he checked them? If it was, you may have a leak in the system.
It would be good if you could get those readings for me so I can help you.
Roy.
Jun 7, 2019 at 5:57 PM
