If you are referring to the blower motor fan, I have to first ask if you checked fuses. When you say no power, can you explain what has no power?
Lets start with a possible fuse. Here are a couple links that explain how to check a fuse as well as replacement:
https://www.2carpros.com/articles/how-a-car-fuse-works
In the directions, it shows a multi meter and test lamp being used. Here are links that show how to use them:
____________________
There two fuses indicated for the blower motor fan on your vehicle. They are located in the vehicle behind the coin tray. See the attached picture.
Check both fuse one and two and let me know what you find.
I hope this helps.
Dec 21, 2018 at 8:09 PM
