Welcome to 2CarPros. (and I believe welcome back)
There is an actuator on this vehicle which is operated by engine vacuum. It controls the air flow directions between the defroster and the panel. I am going to provide directions for replacing it, but before you do, make sure the vacuum supply hose is connected, not damaged, and check to see if there is vacuum to it when you change air flow direction.
____________________________________________
1999 Mercury Cougar L4-122 2.0L DOHC VIN 3 SFI
Defrost/Panel
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Procedures Air Door Actuator Defrost/Panel
DEFROST/PANEL
REMOVAL
pic 1
1. Remove the instrument panel lower panel.
pic 2
2. Remove the actuator.
1 Disconnect the actuating rod.
2 Disconnect the vacuum lines.
3 Remove the nuts.
INSTALLATION
pic 3
1. To install, reverse the removal procedure.
Let me know if this helps or if you have other questions. Also, please confirm there is vacuum to the line. If there isn't we need to look for a problem further up the system.
Sep 19, 2019 at 8:12 PM
