A/C does not blow cold
1988 PORSCHE 944
215,000 MILES • 2.5L • 4 CYL • 2WD • MANUAL
ALTOWNSEND
  • 5 POSTS
The A/C works and blows cool. It does not blow cold. Compressor is engaging, fan motor works in different settings, all vents are blowing air. Air is cool but not cold.
Sep 6, 2018 at 6:14 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Have you had the refrigerant level checked? Your A/C system holds 2.09 lbs of R-12 refrigerant (as long as not converted to R-134a). If system is low you will have those symptoms. Hope this helps and thanks for using 2CarPros.
Danny-
Sep 6, 2018 at 5:53 PM
